Farming101
Just picked up a 228D for my farm. 1100hrs. And it is a very rough ride. I have the adjustable spring suspension tightened all the way and it's still bad. Any thoughts, suggestions, or experience? Thank you!
I was happy with the ride I was getting out of my new Toro Titan but then read on here about adjusting the amount of air in tires. Rear had 15 and I went down to 10 and front had 25 and I went down to 13. It made a difference ... not sure if that would be something you could try. Timm
FYI...anytime you alter the air pressure in the tires, you need to re-check the deck leveling and pitch. The outer(East/West) blade tips should still be very close to even...but the front(North/South) center blade tip pitch could have changed significantly. Just sayin.
I was thinking the same thing so I had my metal ruler out there while I released the air. The rear part of the deck went down 1/16 of inch and front never moved.
