Bad clutch
All good advice given. I replaced one on a badboy this past summer the clutch was a bear to get off. I used a mix of 50/50 of transmission fluid & acetone. applied a couple of times during the day & soaked it down over night. Next morning with a little "encouraging" it came off. Do not forget to put a bolt back where the missing piece was to keep the clutch from spinning or you will be doing this again. If you are buying new go to my Store Front to get a clutch for a lot less $$$. I did not have any issues with the one I bought there. https://amzn.to/3xeYqSl
