Usual suspect is the seat switch.
Mower thinks you are not in the seat so cuts out when the PTO is engaged.
Second option is the PTO switch itself but they are a lot more robust than the seat switch.
Then there is the wiring between the seazt switch, PTO switch & coil cut out.
