oologahan
The left side pump went out on my 2009 7200AOS with the 35hp CAT diesel. I bought a new pump from Bad Boy and drained the fluid, installed new filters (filled with oil and reinstalled the pump with a new belt. I have the rear wheels jacked up and am having trouble getting the new pump to turn the wheel. I have tried opening the valve and bleeding the air, but so far no luck. Is it possible I switched the hoses to the hydro gear wheel motor?
