Just put an older 8hp Briggs together. Mainly just needed cleaned up, honed and a set of rings and lapped and set clearance on the valves. Valve seats appear good. Starts and runs great but has a real hard place in the cycle just as the piston passes TDC on the downward stroke (power stroke). It rips the starter cord out of my hand. Checked the valve clearance twice and ruled out anything else I can think of. I can feel the tight spot in the same spot of the cycle when it's pulled slow. Don't think it's a bent crank since it's fine on the other cycles. I did do a hillbilly plane on the head and block deck with a piece of granite and wet/dry paper but can't imagine removing enough surface to mess up the valve clearance.? Stumped
