exotion
My e-mail service says that rober@honda isn't a valid address.
No, I'm not in Spokane, but in the midwest.
No he's a user on these forums his name is robert@honda
go to honda forum and scroll down to rear wheels locking up posted in june this year, this website, click on forums then honda, hope this helps you out.I have a Honda HRX217HXA mower. It has become very resistant to pulling it backwards when the wheel drive is fully released. It acts like some kind of clutch is not releasing as it should. The front wheels are OK, but the rear wheels don't want to go backward. I've adjusted the drive clutch cable according to the specs in the manual, but that doesn't help. The problem exists whether the engine is running or not. Would appreciate any help in solving this so the mower will free-wheel when I need to pull it backward.
Is your mower in warranty? If you're not sure, share the serial number with me and I can check:
I would of course get it to a Honda dealer if in warranty for sure. If you want to DIY, "hard to roll backwards" sure sounds like the control arm may be binding, or the clutch cable may be damaged or binding. There may be debris or a lack of lubrication near the control arm that is compounding the problem; here's a screen grab from Service Bulletin #93 from April of this year that shows what to do:
Very interesting dickman. Let us know how your beta test goes.
