Here's the video. I'm not touching the throttle. The RPM's went down on their own. A few seconds later, they came back up.
Hello PTmowerMec,
In the video, that sounds like a coil breaking down issue. You would need 2 adjustable air gap spark testers between the plug tips and the coil plug wires. Run the engine while watching the spark jump the gap on each tester.
One coil will spark continuously while the other breaks down and comes and goes intermittently.
The V-twin engines don't shake and rock as people would expect because they are mounted solid.
Sorry, you are using junk spark testers.
Stop it with the inferior spark tools LOL.Note: They're not adjustable air gap spark testers. But I they do show when exactly the voltage comes through. Both sides glow bright.
