Backfire and dying
Hammermechanicman
The ipl for the engine number he gave showed a fuel pump. If it doesn't have a fuel pump what type of fuel filter was installed? If a paper type get the red disk type with the screen in it and see if fhat fixes it. Shouldn't use pleated paper type filters in a gravity system. Not sure what the OP has.
Scrubcadet10
Moderator
Staff member
Yep, you're right.
here's what the pump looks like.
Shouldn't use a paper filter on a gravity tank, but I do. No problems on several mowers. Just saying. Hammer is probably correct about the filter details.
Larrythemowerman
Man mine was doing samething be cutting grass it would just shut down back fire somtimes let set start back up somtimes pull it back to garage check oil pull plugs out everything wiggle key switch started wiggled it again quite so all was was keyswitch lol
