Bigjimwhite
- May 12, 2021
- 1
So I have a 2002 725k with a manual deck. I raised the deck to sharpen the blades. Got all done and put the deck back on the ground. Put the deck height lever back up and the back of the deck drags the ground and won't raise when I raided the deck. Just the front goes up and down but not the back under the foormt rest. It drags. I had this problem 2 years ago when I cleaned out the deck and figured it out back then but for got what I did to correct it. Any help would be greatly appreciated. Jim
