back again JD LT150
JamieL1
got it going...ran and cut like a charm over the weekend...got it last night to move and nothing...just turned over & over....could it be a valve issue?
mechanic mark
post all engine information, make & all information from data plate.
If Kohler engine no valve adjustment, hydraulic lifters, see troubleshooting section 3.1 in manual above.
Possibly, may need to adjust valves with engine cold, post all engine information, make & all information from data plate.
If the mower still has its original engine then OP can't adjust the valves since it is a Kohler CV15 with hydraulic lifters.
Here is a question has the OP a shot fuel in the carburetor to see if it is a fuel problem or other problem?
JamieL1
If Kohler engine no valve adjustment, hydraulic lifters, see troubleshooting section 3.1 in manual above.yes i
yes it is a 15hp kohler cv15s-41618
