I am hoping for at least a month maybe 2 before I remove my mower deck and mount the snow blower... but I'm a lot farther south then you... :smile:KennyV
Hi Kenny. I am just hoping for two weeks. We had frost this morning and yesterday. I am slow as mollasses in january, but will be humpen to get er done. Dusty
I discovered several years ago, if I mount my snowblower on my ZTR before I need it ... I usually do not need it all winter... but if I fail to have it on, I am usually working in snow drifts before I can get it mounted... :biggrin:
:smile:KennyV
Well I finally got started. I knew the tractor was in rough shape. That is the only way I buy them. But I have had tis tractor for almost two years. It has never let me down. Leaks oil leaks hydo fluid. I just make sure everything stays full. The clutch is frozen ( rusted to the pressure plate ). Hood and fenders are messed up or rusted or both. Wow. Well it should be fun.:biggrin: Dusty
I removed the fenders , hood and side panels and washed it as well as I could. Transmission was smashed in at some time and it looks like they tried to fix it with bondo. It leaks a little bit but the big offender is the mid pto seal. Trip to Kubota tommorow.:biggrin: Dusty
Castings/covers are sometimes easily broke... Looks like you are well into a GREAT restoration build... You will have a great little tractor in the end... Keep the pictures coming. :smile:KennyV
