Beardedrooster
- Oct 16, 2016
- 6
I went and pulled the valve covers, everything looks good visually, the push rods are all in the correct location none had came loose, would a valve being out of adj. Cause issues like I'm experiencing, I haven't checked clearance only a visual test. I shot another video of the mower now the idle doesn't seem as bad as it perviously did but engaging the blades bogs the engine down extreamly and kills it now,
https://youtu.be/6v2-YiRmmnY
