nullRequest
- Jun 18, 2015
- 2
I've got a B&S (125K02-0187-E1) that won't stay running. I've done a bunch of research and the obvious culprit is the carb, but I just replaced the entire carb with a brand new OEM one, and it didn't help. It was a replacement motor I got on Craigslist to replace the one on my Super Recycler that crapped out. It feels like it's got good compression comparing to other mowers I've had in the past.
The weird thing is that if I start it (with a small squirt of thrust), then restrict the air intake on the carb, I can get it to keep running (basically a redneck choke). Here's two videos showing what's happening.
This one shows it will start, but die almost immediately: https://vid.me/9C19
This one shows me keeping it running by covering the air intake with my hand: https://vid.me/PMbH
Brand new carb, spark is good and right gap, fresh full tank of gas. After new carb didn't help, I just replaced the oil, which was pretty dirty, so I put some seafoam in the crank case to run a bit. Before I put on the new carb, I could get it to keep running if I kept pushing the primer and feeding it more gas, which is why I figured maybe the carb was clogged/shot so I took a chance on a $30 new carb, which didn't help.
Thoughts?
Thoughts?
