Parts list shows a magneto.Your engine ignition has probably been converted to the Magnetron ignition, so as points and condenser not required. The magnetron is a good thing.
Oh, it also show points and condenser.
A tank that old, I doubt was clean. Have to take your word on it. If it came with points she is an old girl.check fuel tank it was clean
Found dirt in carb but not in the tank. Ok......Removed carb disassembled found old gas residue and some dirt
Was the throttle plate and choke wide open while doing the above test?Check compression 85 lb with 6 pulls, exhaust not obstructed
