Greetings, I have a B&S v-twin vanguard model# 356447 code #06062211 type #0200-E1. The engine has about 3000 hrs on it.
Today it has seemed to develop a drip of gas from a vent on the outside of the carb. What may be the cause of this? Stuck float? Fuel shut off valve not operating properly? Please help me understand if what I have read is correct. It is my understanding that on older engines/ carbs they had this outside vent and we could see if gas was leaking. On newer models because of EPA the vent is on the inside so gas drips into the engine.
1. What causes this drip?
2. Can a older carb, or carb top with a vent be adapted to fit on a newer B&S engine of the same variety so we can see if gas is leaking and not going into the cylinder unnoticed?
3. At what time frame as in hours on a machine is it advisable to replace carb gaskets, float valves, etc.?
Thanks for any help
Thanks for any help
