B & S running rough model # 96114000718
jadester
Hi. newbie here. got a little weed eater mower I use for places I cant get with rider. Its got fresh gas, clean air filter and new plug. So I figure it must be carb. When I took off air filter I noticed the small spring was broken. Thereare two on the carb. would this make it run rough? Any help appreciated......Brad
Please post the numbers on the black metal shield over the muffler. Would make it alot easier for us.
jadester
OK. Sorry about that. 300 series model 9S502 Type 1019B1 Code 08041715
anthonysemech
To verify you have a fuel issue spray carb cleaner in the throat of the carb-then start it- if it's starts and dies then you have a fuel issue. But it won't rule out if you have compression problem. Then rebuild the carb.
jadester
Is there anyplace I can get just the spring? thanks
jadester
got her running better. thanks so much for the help....Brad
