AcreageMowing
- Nov 17, 2024
- Threads
- 1
- 4
I have a B&S Quantum XTS 50 serial 12F802-3112-B1
It won't pull start on gas.
Replaced the primer bulb and checked it works.
The air cleaner assembly MAY be warped and I will replace that next, I understand that can affect starting but should not affect running.
(edit: the primer bulb does not prime the engine - it does puff air, and the gallery to the bowl is clear but no fule bubbles up the jet out the nozzle, so I am pretty sure the fault here for not starting must be a warped cleaner assembly (thanks to StarTech below) ).
It starts well (1 or most 2 pulls) on a squirt of ether and runs strongly while it has ether, responds to throttle, does not hunt, then stops when ether is used up.
Spark is good.
Compression is OK.
Fuel to carb, fuel in bowl.
Does not seem to be sucking fuel across the jet.
I replaced the carb with an aftermarket one - same problem, same symptoms.
I cleaned the old carb and ensured all jets and tubes (primer) are clear and float needle works.
New gaskets on both sides of the carb.
Any suggestions on what may be the issue are welcome.
Spark is good.
Compression is OK.
