B bartles Well-Known Member Joined Jun 28, 2016 Messages 331 Aug 16, 2023 #1 Received piston with ring set, part number 594539 for a 31C707 0254 E1...the two top rings have color code markings...can someone advise(mounting order top down) which color ring fits to the piston?
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,527 Location Pluto Aug 16, 2023 #2 Please verify your model type numbers. I see no 0254. Also the piston assy is for Now this might be a superseded part so the model and type is important to look up the correct parts. And i would have contact Briggs about which order they go in and which is top and bottom of the rings.
B bartles Well-Known Member Joined Jun 28, 2016 Messages 331 Aug 16, 2023 #3 Well me and my fat fingers really screwed that up: 31C707 0154 E1
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,527 Location Pluto Aug 16, 2023 #4 Standard piston. 594539 is a supersede for 796172. 796172 > 594539 Before date code 14100100 594435 After date code 14093000 Should have come with a cheat sheet but I see if Briggs is of any help it may take a few days. email sent to tech support.
B bartles Well-Known Member Joined Jun 28, 2016 Messages 331 Aug 16, 2023 #5 Thank you for your help!
