B&S magneto
Geochurchi
Hi All, there are 2 wires on this magneto, 1 goes to ground terminated right on the mag mounting screw, where does the other wire connect? 1 obliviously there is the plug wire there also.
Geo??
olgeezershonda
When you say "this magneto" do you mean it's different than the old one? What model and serial number is it going on?
Scrubcadet10
Moderator
Staff member
Gonna need the model and type and numbers of the engine
Geochurchi
Sorry, here is the info.
6R6. S/N 371353. Type 105878.
Scrubcadet10
Moderator
Staff member
Old models are usually stamped around the spark plug area, flat heads.
