B&S leaking gas out of carb
Demon1977
I have cub cadet push mower with a B&S 675EX with ready start that's leaking gas out of the carb I've taken the carb off and clean the float and made sure it was moving freely but it's still leaking
Any help would be great
You need to replace the needle and seat in the carb. The rubber has a habit of breaking into small pieces, and swelling which prevents proper sealing. Need to either install a carb kit, or at least a needle valve/seat.
reynoldston
I couldn't answer this any better then this.
