Hi,
I recently purchased a 2003 Mountfield 625m rideon mower that doesn't start and trying to resurrect it. Its manual choke manual start, Engine number is 122602 0181 E1.
Steps taken so far:
Oil filter and oil change
Fuel drained, new fuel filter fitted & inline fuel tap on hose, new fuel added
New choke cable (old one had snapped)
New air filter
Checked and cleaned spark plug
So after the above, it started briefly on occasion for about 1 second and then died. Next step was then:
Stripped and cleaned carb, new fuel bowl gasket
I've reinstalled the carb but not getting any sign of life from the mower. Unfortunately I removed it with the air filter housing in place so don't have a photo of the linkage above it before I removed it and I think I've got something wrong hence the carb isn't opening. I've taken some photos to show the issue hoping someone can help:
Photo 1, current state of carb linkage from above:
Photo 2, where should this spring be connected to?
Photo 3, there is currently nothing connected to what I believe is called the choke plate
Photo 4, this part seems like it should be controlling the choke plate but not sure how
Photo 5, this would seem a likely setup for the choke plate but as soon as I let go it all springs apart again, and even with the air filter housing in place it still springs apart
I guess I have a couple of issues.
1. The choke plate is not getting moved by anything, presumably this should be done by the choke cable but as per pic 5 I don't know how.
2. The spring in photo 2 needs to be connected to something.
Any guidance greatly appreciated.
Matt
Steps taken so far:
New air filter
Matt
