B&S Ignition problems
BernardLuz
Hi,
I have a 130G series B&S engine about 7 years old and powering a McCulloch rotavator.
Having established that there was no spark I purchased an OEM ignition coil and a couple of spark plugs for good measure.
I have fitted the new coil, gapped it on the flywheel with a business card but no spark.
I have disconnected the kill wire and still no spark.
Help please
mechanic mark
Is equipment kept inside shed etc.? Is flywheel rusty or clean?
Post Model xxxxxx, Type xxxx, Trim xx, Code xxxxxxxx numbers from engine & part # from new coil & spark plugs, thanks, Mark
BernardLuz
Hi mark it is kept under cover but I am in Portugal and it doesn’t rain that much. Flywheel is clean
