UTBMXCruiser
- May 2, 2016
- 5
I have a 21" Toro with an OHV 123602-0132-E1 Briggs and Stratton engine that I have totally lost engine speed control. I bought this mower used years ago and the throttle has never been right. It has never reacted to the throttle lever in any position. It has always just run at what would be normal full throttle governed engine speed in any position of the throttle lever other than all the way back to kill the engine. Now when you start the motor it goes wide open into an overrev condition where the governor is not pulling out throttle at all. All the governor linkage, rod and spring are all hooked up and free of trash. It all moves around in what would appear to be a normal condition, but yet it just goes nuts when you start the motor wide open. What should I do to troubleshoot this issue????
