B & S Flywheel Magnets
We need a picture of the flywheel for reference. There are different designs.
What engine number is the flywheel on?
If it is only for triggering the coil, I don't think pole direction is important. If it is the magnets attached to the underside inner portion of the flywheel then the poles have to alternate between N. & S. polarity.
Type this into your search engine and I’ll bet you’ll find the answer to all your questions. how do briggs ignition systems work diagram
I’ll find the engine number after the first weekend and may be open the engine. I am interrested in the MAGNETRON ignition system with two Darlington transistors. This ignition system made the B & S engines more reliable.
This summer I made a barn found:
42 years B & S Magnetron engine with generator: It fired after using the recoil som times.
Yes the polarity is important. That why some old point systems [cast iron blocks] will not work when converted; until, the magnets are re-polarized; otherwords, the North/South flipped. This because the cast iron point system used a positive ground vs the current negative ground system.
Opps showing my age...
Hi StarTech,
I had forgot the differences between coils because I rarely get anything with points anymore. Points ignition systems were just being phased out back when I was starting out many years ago.
I had also certainly forgot about the flywheel magnet polarity and correct coil mounting orientation.
Here is a video that I found online:
Please see my appended drawing. Is the Magnet configuration Correct? Nice if you have comments either if the drawing is correct or not.
Regards
Gunnar
IF you have the flywheel at hand why use an old compass. Or have a non metal dish or plastic. Magnetize a small sewing needle, fill the container wit water, gently place the needle on water surface. Now if know generally which North the end that point North is the North end of the needle so note that. Now take the same and place near one of the magnets and the needle will tell you which pole it is.
Since I didn't have a compass here that what I use to setup my North to North swing of Cushcraft A4S beam antenna
Why not a pocket compass?
Even a pocket extension magnet will also point out opposing fields of magnetic polarity.
I am still wondering where this post is going. I have not come across a flywheel with NSN magnets mounted externally for the ignition coil induction.
A picture of the actual flywheel would give us some clues.
