- May 6, 2010
- 11,983
First the throttle speed control is over rotated. the linkage between the governor arm and carb is backwards, and the throttle shaft needs to be flipped back up over the stud, so it rotated clockwise.
Rivets, the small spring is the auxillary governor spring.
