ecarter312
I have a B&S 11.5 hp (model 217902-0015-G1) engine on my Snapper riding mower. During use, the engine just quit and will not restart (note: in the past it's always started on the first pull...never had a problem starting). Here's what I've done so far:
!- Refilled with fresh gas
2- Removed and cleaned the carburetor (although mower is 10 years old, the carburetor was replaced last summer)
3- Installed new fuel and air filters
4- Installed new spark plug and verified that the plug is sparking
5- Adjusted the valves to factory specs
6- Checked oil level
7- Tried using starting fluid
Still will not start. Any suggestions on what to do next would be appreciated.
