Kennykenny
Make sure all the governor linkage and springs are still connected.
All connected as far as it looks to me.
According to your picture, the throttle valve is not hooked up to anything. Thus, it is randomly vibrating around and causing the engine to run at random speeds. I'm on my tablet so I can't circle the problem, but here's a page that shows how everything is supposed to be attached. Note that the engine pictured does not have autochoke.
Compare it to your picture and I think you'll see the problem. http://outdoorpowerinfo.com/repairs/briggs_lms_carb_linkages.asp Don't follow any of the instructions on the page, just hook up the linkage the way it's shown.
I'm surprised the mower ran long enough for you to use it the first two times!
I'm guilty of missing it a few times as well. :ashamed:
