B&S Apparent Fuel Supply Issue
rfisher
I have used the two part epoxy in the past, but if you have a hot glue gun that works too. The hot glue is gas resistant. Have repaired plastic tanks that have split or cracked with hot glue when a tank was no longer available.
Thank you, I'll try that!
Fisher are you wanting to fix a solenoid ????? Or get a quick fix for getting your mower running ??
rfisher
Fix (as in restore to its original functionality, not castration).
As a temporary/diagnostic step, I removed the plastic tip and reinstalled the solenoid.
rfisher
(Please note that I'm not the original poster.)
Okay, I removed the tip from the solenoid plunger, then helped my brother reorganize the shed while my sister-in-law mowed their yard.
Then my brother used it to mow our mother's lawn.
It sounded great and didn't stall or stutter, so I'm convinced that the loose tip was the (current) problem.
After that, I took a suggestion from ILENGINE and tried a bit of hot-melt glue to reattach the tip to the solenoid plunger. I reinstalled it yesterday, so we'll see if it holds-up when I mow the lawn next. The glue that I used was just whatever residue was left in the gun from its last use. Hopefully, it won't remelt and clog-up the carburetor.
Thanks all for the help!
