grapnell
- May 10, 2023
- 3
Okay, so I am new to this forum, so I apologize ahead of time if I am breaking any policies. However, I have searched/Googled/YouTubed exhaustively and cannot find much information about this model engine. I recently bought a 9HP vertical shaft B&S engine, brand new still in the box (though an older model) and I am using it as a pet/learning project for me. Essentially, I am installing it on a standard lawnmower deck (don't laugh). So far, I've been able to modify the mounting flange on the deck to install it nice and snug, and everything seems centered up nice. Blade is installed and looks good. However, I am unable to figure out how the throttle/choke system on this motor works. It is a model 288702 vertical shaft, and I have not been able to find any information about this motor online other than a few parts diagrams at third-party resalers.
Basically, I cannot figure out what kind of throttle/choke cable I need to make this engine work. It doesn't appear that the standard Z-bend cable attaches to it, unless there is something I'm missing. See attached pics. I am perfectly fine with buying a new throttle cable, I just want to make sure that what I buy is going to work. It appears that when you pull the throttle cable out to the maximum, it chokes the carburetor.
Please, any advice on what I might need to do?
Thank you.
Thank you.
