B&S 675 Series Oil leak from casing
almighty1
Hi,
Getting the following oil leak from the area in the attached pic. Seems to bubble up a bit.
Anybody any idea what could be causing this?
Much appreciated.
Hi,
Much appreciated.
My opinion is that there is a worn O-ring that needs replacing.
There is a screw at the top that holds that filler tube in place.
Remove screw, lift up the tube, replace the O-ring and push the tube back in, replace screw.
if it is exactly where your arrow is, there is a crack in the housing? maybe the housing bolt was loose and vibration cracked it, or it was over tightened.
Thanks Shift, I'll have a closer look when I return home. Thanks for your time.
