xeribis2014
B & S 5 hp, 130202-15, having difficulty staying running, linkage/mixture problems?
This is a Briggs and Stratton 5 hp engine, model # 130202-15-01, and is on an old Kemp shredder. Everything on the engine worked fine, except when the shredder got a little bogged down with just a little too much debris, I would have to close the choke to give it more gas.
Well, this machine vibrates severely and the intake manifold came loose from the engine and I let a tweaker mechanic try to fix it. Now, several hours and a new tank gasket and new governor spring later - the engine starts great but quits about five to fifteen seconds after starting, with or without a load ( meaning with the drive belt connected or not). I checked the intake under the air cleaner and it looks dry, and I checked the spark plug and it is good and has good "color" on the tip - whitish brown. My thoughts are that it is a fuel related problem, but I'm not sure what to do next?
I noticed the tweaker mechanic had some issue with the governor rod and spring, and he fought with it for hours. I eventually sent him home and disassembled the engine from the shredder and took the tank off, and then the carb. I remounted the carb, remounted the tank, replaced the governor spring and thought I had everything assembled right, but it will not stay running.
Also, the pull starter makes an awful racket for about twenty seconds, and it usually happens about ten five to ten seconds after start-up, then goes away
Anyone have a good line on how this engine works? I tried to download some manuals on related topics but was not able to?hanks!!!
