B&S 5.0hp 130202 3166 01 throttle likage.
silver1
On this motor, which way is fast..........slow idle? left is ? Right is ?
All the way left has a ramp to stop the motor with the kill wire.
Fish
Under normal applications, the far side would be full choke, and the other settings for running "off" choke, etc......
silver1
? far side ? Motor has a manual choke off a rototiller.
When you move it closer to the kill wire you should be decreasing speed. Simple as that.
silver1
OK then. thank you It will only start/run at the far left (shown). If I move it at all it stalls. It will start at first pull with choke on.
I can move the choke off and it runs good.
