silver1
- Oct 4, 2012
- 81
- 415
On this motor, which way is fast..........slow idle? left is ? Right is ?
All the way left has a ramp to stop the motor with the kill wire.
Under normal applications, the far side would be full choke, and the other settings for running "off" choke, etc......
When you move it closer to the kill wire you should be decreasing speed. Simple as that.
