B&S 31P777 won't turn over after replacing head gasket
RicktLawton
  • / B&S 31P777 won't turn over after replacing head gasket
I Have completed a head gasket replacement on the 18HP engine in a John Deere tractor. I set valves to .04 Intake and .06 Exhaust. When I start it it turns part way, then stops. As I continue to start it it moves a little then stops. This continues through the full engine rotation. If I remove the spark plug it cranks normally. Any ideas would be appreciated.
Bad ACR on camshaft which would mean the camshaft needs replacing. You might even need a new governor gear.
Former Camshaft kit 793880 superseded to 84005207 which no longer has the two 690564 tappets (lifters) included. They must be ordered separately.
RicktLawton
Many thanks for your help.
