wywy
- Nov 26, 2025
- 14
Hello everyone first time here, I have an old snapper mower with a b&s 303777, I did the rings on it and I cannot get it to run right, a little recap first though, the cylinder that runs the fuel pump was down to about 10 psi, 2nd was around 30, so I disassembled and got new rings for it, also lapped the valves, then it seemed to be seized apparently so I left it in my garage for about 2 weeks because I went on vacation to my grandparents house, when I got back the engine rotated fine so I got a new starter and it ran but very poorly, after about an hour of running I saw that the exhaust pipe midway down was glowing red hot, so I shut it down and let it cool and then I was just busy for a very long time so I never did anything with it, I started it up again for some more diag about 3 weeks later and noticed that the choke seemed to be controlling the rpm, and also about 30 seconds of running was making the exhaust pipe smoke, it again sat for about 2 weeks, I came out a couple days ago and it does the same thing but now it is very difficult to even get running, when I turn it over it fires for about a second then I can see the governor slams the throttle plate closed and then the engine dies, I have made a few attempts and got it to run but still the rpm is controlled mostly by the choke, exhaust also smokes in about 10 or 15 seconds, I did take the govenor system off and throttle system off more times then I can count and tried putting springs in different locations but nothing really fit so it's all back together I'm what I remember is the correct way I'm more of just at a loss of what's causing this, carburetor was dirty but I cleaned it out and stuff but the carb was never an issue to begin with, I have ran it off starter fluid for a lil bit but I still needed the choke to be almost completely blocking air off for it to run, when it has run the more I block off air using the choke the faster it runs, I am 17 and I don't have a ton of knowledge on this kind of stuff but I'm kinda thinking I wrecked the governor or throttle system, would appreciate any ideas that anyone might have thank you
