B&S 20 hp V-Twin...Piston Play at TDC...Should this be?
kailor
Hello. I'm working on the following mower:
Model 406777
Type 0128-E1
Code 030516YG
John Deere L120
GXL120A062841
I'm replacing the head gaskets. When each piston is at TDC, I can take my two thumbs and move the piston side-to-side ever so slightly. Is this acceptable or indicative of a problem?
Thanks
Keith
Acceptable... and actually desirable.
If this did not happen, engine would seize due to expansion at running temperatures.
