J jcullen Forum Newbie Joined May 10, 2017 Messages 4 May 15, 2017 #1 B&S 407777- 0174>>>>> Can I do away with the fuel pump and just use gravity and a petcock shutoff?
reynoldston Lawn Pro Joined May 23, 2011 Messages 5,705 May 15, 2017 #2 Don't know why not. The fuel pump is just a low pressure pump. All you would need is a good flow.
NorthBama Well-Known Member Community Leader Joined May 28, 2014 Messages 938 May 15, 2017 #3 if the tank is above the carburetor it should work
