Namestaken
- Sep 17, 2019
- 1
- 5
I have a Briggs and Stratton 128M02-0133-F1 on a push mower that won't start. Diagnosing this is my intro to small engines so I'm pretty green. I've done a few things to try to fix it thus far but nothing has worked. The things I've done:
Any ideas you can share are greatly appreciated!
- Replaced spark plug (it was pretty clean, set the new gap @ 0.030)
- Replaced oil
- Replaced gasoline
- Replaced air filter
- Tried starting with gas cap off
- Rebuilt the carburetor twice, then replaced the whole thing anyway
- Replaced a cracked intake manifold
- Replaced air vein and choke springs (mower ran poorly before it stopped working)
- Replaced rusted thermostat (aligned with air vein bracket marks)
- Replaced coil/armature/magneto (set air gap to 0.011)
- Verified magneto primary and secondary resistance
- Used ignition tester to verify spark should be occurring
- Removed cylinder head and verified it was clean inside
- Verified valves and piston open/close
