eromlige
- May 17, 2014
- 1
- 5
Briggs & Stratton: 125K09-0266-E1
Family: 2BSXS.1901VH 275260
OK, Having a hell of a time starting this beast. So, I decided to take a look.
I've removed:
1) Housing cover, Housing blower
2) Fuel tank
3) Magneto
4) Air Cleaner/Cover
5) Auto choke (having taken it apart yet)
Ok, so I did this because the "Touch-N-Mow" starter deal didn't seem to be properly meshing with the gear that I believe is on the side of the flywheel.
Which means that instead of the once nice positive spin up and start of the engine, I now get a sick plastic-ky .... BrrrrrraaaaaaPP! If the touch-n-mow starter is charged (has tension) when I try to start the mower. Which means I use the starting pull cord. Which is so stuck/bound that the flywheel barely turns.
So I take off the cover and notice that the flywheel actually contacts the magneto (one spot) and has worn grooves into the side of the flywheel.
First question, is this supposed to be this way? Does the magneto usually touch the flywheel as it spins?
So, now I figure, OK, at the very least I'll clean the carb (autochoke), replace the air filter before I put this back together.
Next question, is there a parts/repair manual somewhere with the specs? (float level, plug gaps, etc.)
So while the top of the engine was apart, I figured, let's try to spin the flywheel now. Well it's still pretty darn stiff, am I just wasting my time?
Well, thanks in advance for any input. I could use some help.
Oh, yeah, this thing was running like 2 days ago, and yes it took a looooooong time to get it to finally fire up.
I've removed:
2) Fuel tank
3) Magneto
