looking for suggestions on what to look at...
well used murray lawn mower
b&s 12.5hp engine flathead model 28v707
smokes on startup and while running, oil fouled plug, misfires when running but gets better when hot
pulled the head and quite a bit of oil in cylinder...installed new head gasket and spark plug.
installed breather tube between carb and breather (wasn't there before) still smoking (maybe a little less)
cranking compression 105psi
if rings were the problem would the compression be lower? or is the oil causing them to seal during testing
looking at the diagram there's no valve seals? so just the bronze bushing seals them from the crankcase?
maybe i should give it the seafoam treatment and see if it improves
any help is appreciated
