montypython
- Sep 30, 2017
- 2
I have a MTD RH125/92 (13AC458E600). I think from about 2002 as it came with the house when I bought it 5 years ago and has run great ever since. However recently it has started to want to stall when it is under load. It’s okay on dead level with deck engaged but if you come off clutch too quickly or it’s on a slight incline or full lock it splutters, backfires and will cut out if continued to drive. It has a B&S 12.5 I/C model 28T707)
I recently renewed the air filter, the air filter that was removed had a hole worm through about 1.5 inch in diameter so I guess it was naturally running weak, however the plug looked a good biscuit brown colour but was heavily built up so I replaced with OEM plug of correct type.
After the filter change I the plug is much darker – running rich I would say. I tried adjusting the mixture and removing the air filter but it makes no difference
The mixture screw still has the cover on it so it allows about 2/3 turn of adjustment, it was fully screwed in to the stop, I have tried adjusting but it makes no difference. Is it screw in to weaken?
I seem to get a lot of backfiring and I also noticed air movement I the bottom of the Air filter tray when running.
Any help anybody could offer would be gratefully received as I’m starting think it may be time to change – shame because it has been a great mower
Thanks in anticipation.
