jaylees150
UPDATE
Having re visited this today in the daylight while I had some time, I have the throttle cable connected up and functioning properly. And I have the governor linkage and spring connected up as well. With the engine shut off I can manually push the throttle plate closed and it springs back nicely.
I re connected the battery and tried to start it with the throttle lever in the low revs position without success. As of right now I have nothing to connect the choke mechanism.
