B&G V TWIN riding mower, LOW power
beljohns
Sorry for not updating this thread, had some work and family stuff come up and I haven't had time to work on the mower. I will continue with suggestions made thus far and post results. Thanks for help thus far.
-Ben
beljohns
Finally got to work on the mower tonight, with good progress. I started by running through the purge air procedure several times, didn't really help and checking fluid level in transaxel it didn't change. So laying underneath the mower, I just happened to try and rotate the idler pulley...and it rotated very freely. After playing around it I realized the bolt that runs through the pulley to tension bar was caught on a metal lip or something, I pulled it down, let it go, and it shifted the pulley quarter inch or more. Rotating the pulley by hand was much more difficult now, belt much tighter. Driving it around the yard now I had some power! Almost 100%.....but still not quite.
What I'm observing is the new left side transaxel although so much better, still doesn't have quite the power of the right side. And, if I push the control arm all the way forward, it actually bogs down a little. If on a slight hill, and just doing a circle by using a single control arm, the left side is still not quite got enough power. This makes me wonder if there is still some slipping on the pulley going on. So, I'm thinking either the drive belt is not quite right size, maybe a little big...or the tension arm spring may be wore out? I did put a new belt on, however I went the cheaper route and bought a PIX brand off Amazon, it says it replaces the original 754-04043 I find listed on parts tree for this RZT 22. Any thoughts on the value of buying a Cub Cadet belt vs PIX? Also, should I be able to still turn the idler pulley wheel by hand? I can do it a little (before it was super easy).
thanks,
Ben
beljohns
So I just wanted to follow up in case this could help someone else. After more scratching my head, I realized the motor only had 2 bolts holding it to the frame and those were loose. I'm guessing someone maybe took it off once, I don't know. Anyway.... I went and got 2 more, and after putting in all 4 bolts it apparently shifted the motor enough that I don't have any more issue with the pulley wheel hitting anything, and it seems to now be putting enough pressure on the belt. Driving it around I do not feel any issues or lack of power, in fact the newer transaxle side has a bit more power than older one - to be expected.
So, in the end.... after replacing transaxel due to no power and cracked housing, the observed low power was due to not enough pressure on belt. Obvious thing right now, but everything "looked ok" until I started manipulating the pulley and belt and realized there was too much "loose". I'm sure all the other things I did didn't hurt, and were needed to just make it healthy.
Hope this gives someone an idea in the future.
logan01
That was my next suggestion.:laughing::thumbsup: Glad you got it. One for the books.
