axle bearings
mkjr63
any one figure out what size needle bearings go in the 618-3150 bearing blocks on a 3000 series rear outer bearing block... cub sells the complete block and bearing for a out ragious 52.00 per complete block and bearing... when the actual needle bearing is less than 7.00 to buy online
motoman
Unless you must stay running, have you tried to read any PNs stamped on the bearing. Otherwise a starting point is OD , ID, depth, number of rollers, etc and lots of onlne searching. Gotta believe someone here will advise....
reynoldston
I would say motorman has it mapped out for you very good, not much more to know :thumbsup:
