I have a cub cadet 1050, the auto comp release is not working.
N newcoro1 Forum Newbie Joined Sep 15, 2015 Threads 1 Messages 4 Sep 15, 2015 / automatic compression release #1 I have a cub cadet 1050, the auto comp release is not working.
L logan01 Well-Known Member Joined May 13, 2014 Threads 7 Messages 313 Sep 15, 2015 / automatic compression release #2 Thanks for letting us know that.
N newcoro1 Forum Newbie Joined Sep 15, 2015 Threads 1 Messages 4 Sep 15, 2015 / automatic compression release #3 To start the engine I have to first, by hand back off the compression stroke to get a running start & have the battery with a full charge.
N newcoro1 Forum Newbie Joined Sep 15, 2015 Threads 1 Messages 4 Sep 15, 2015 / automatic compression release #4 I am trying to make up my mine if I want to tear down the engine to replace the cam. I have rebuilt VW engines, but I never worked on these engines.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Sep 15, 2015 / automatic compression release #5 No great secrets to doing small engines. If you told us what engine it has we could have pointed you to the appropriate service information. Have you tried closing down the valve lash a bit ?
L logan01 Well-Known Member Joined May 13, 2014 Threads 7 Messages 313 Sep 15, 2015 / automatic compression release #6 Sounds like valves need adjusting.
N newcoro1 Forum Newbie Joined Sep 15, 2015 Threads 1 Messages 4 Sep 15, 2015 / automatic compression release #7 Thanks for all the help! I reajusted all the valves to a tight .004, it is starting much easer.
