EngineMan
- Jun 12, 2012
- 9
- 2,275
Maybe, I don't know to be honest. There's a shutter inside the carb that I can't see when the carb is installed on the mower. Then there's a shutter right there on the outside of the carb, which I posted a picture of, that you can see when you take the air filter off. When that is open, the mower runs ragged and gets way too much fuel. When it is approaching closed, the mower runs better, but the spring/arm is allowing it to flop back and forth and it is still too rich and sputtering eventually losing power to where the engine dies. If I take a screwdriver and hold that shutter closed, the mower runs at top speed with no sputtering at all, but it's running to fast for me to just manually close that up. I can pretty much get the mower started whether it's cold or warm, but it just won't run worth a squat. Again, I'll post a video soon that shows what it's doing as I'm sure that'll show much more accurately the symptoms versus my ignorant ramblings. :smile: I understand the basics of how engines operate, but I'm still learning the nuances of all the various systems on all these various mowers. I wish they'd all come up with something that works and leave well enough alone. I've got 5 push mowers, 4 of them the same brand, and every single one of them handle the choke and throttle differently. (sigh) I don't mind learning, I just have a hard time keeping up with all the changes the older I get. :confused2:
You can see the choke shutter in your second photo, yes the one on the outside of the carb, if it runs ragged and gets too much fuel then there is something wrong with the carb. also check the gasket. (O ring)
