I have a 5-year old DR Power Field and Brush mower, that is equipped with a 656cc, 20 HP, B&S motor. The motor model # is 40S877. The machine is only used around my own property, no commercial use. I may have 150 hours on it.
I was having issues with it running rough, surging and backfiring, but more on an intermittent basis rather than all the time. I added new gas and Seafoam additive, without much difference being realized. I decided to change the plugs, fuel filter and air filter, but it was still running rough. I figured it was probably a carburetor problem, so I researched a rebuild kit for it. I found out that for less than $20.00 more than the cost of a rebuild kit, I could buy a new carburetor. I bought the carburetor, installed it, and it runs much better. However, another problem arose with starting the motor. It would only start if I gave it a shot of starting fluid!! I thought that maybe the fuel pump was bad, so I just got through installing a new one of those. And....it still won't start unless I use starting fluid, even if it's been run a while. Any suggestions? Thanks!!
