TomSelleckNumber1Fan
- Aug 27, 2013
- 2
- 7
Today I emptied and cleaned out the gas tank, ensured the fuel line was clean and free of debris, and filled the tank with high octane gas. I took the carb off, sprayed all the jets down with carb cleaner, and didn't see any obstructions in any of the tiny holes. I also replaced some of the seals and gaskets on the carb, including the pin and the seat that connect to the float.
If I spray carb cleaner in the carb throat, it will crank for a second or two, and then die. Outside of that, I can't get it to crank no matter what.
Anyone have any ideas?
Thanks
Thanks
