Armature air gap
wellsken
I have a b&s 28N707 15 hp ohv engine which I am putting a new ignition coil on. I went to the Briggs and Stratton website to check specs for this engine model, and it doesn’t show up on the list. Would there be some other number I should be looking for, as there are not any model numbers listed which have a letter in the model number, on their list of ohv engines.
Also, I have looked thru the posts of threads on this engine and I have noticed from 13.5 hp to up to 15.5 hp engines all with the same model number. Is that a common thing to see with Briggs and Stratton engines?
You will find it is about the same as a normal business card.
If you get shirts in boxes with stiff plastic covers on them they are usually about .012"
