Ariens Zero Turn Ikon XD 52 - dead!
JP98
Hello Friends-
I am in need of help!! My zero turn Ariens Ikon XD 52 won't start! It was working fine last weekend when I cut my lawn. I turn the key and it does nothing. I tried jump starting it and still does nothing. It doesn't even make a clicking sound. I thought it might the ignition switch so I bought one, replaced it and still nothing. I jumped the starter solenoid and still no response! It did not turn the starter. The handbrake is up, which is required to start it. Any suggestions are surely appreciated
I would start with checking the battery and/or charging it. If it didn't crank by jumping the starter solenoid I would be leaning toward dead battery.
MParr
Dead battery.
PTO switch is on.
Faulty safety switch.
Blown fuse.
Bad ground.
JP98
I have One of those portable jump starters. I tried it and it didn't crank. But I guess I didn't leave it on there long enough. I'm going to charge the battery all day tomorrow. Thanks for your suggestion.
JP98
Dead battery.
PTO switch is on.
Blown fuse.
Bad ground.
Yeah I will try to charge the battery tomorrow.
PTO switch is not on. I made sure.
Fuse is not blown. I checked
I don't think it's a bad ground but I will triple check it.
Could be a faulty safety switch. Is there any way too bypass it just to test?
MParr
Check the wiring diagrams. You will need the model number and serial number to find them.
